Update on the GreenGlides upholstery tool project
After a lot of testing and dissecting and tweaking we've gotten to the point of me handing the tool back to Westpac and say let's run with it.
The all titanium head will have a very large view window on the front and a inch and a quarter internal hose setup in 10, 15 and 20 ft options
The 01 single jet sits in its own spray chamber that offers amazing over spray control allowing you to clean microfibers and other flat weaves in the very tidy way
The Glide is easily removed if you want to detail staircases and not fret about damage that the tactless will do to your soft Teflon accessory.
There will be a optional and removable heat creating circulating system that will fix to the other end of the hideAhose for those that feel they need full truck mount heat when cleaning upholstery.
I call the Glide an "accessory" because the hand tool also works very well without the Glide when needed such as when doing detail work or very rough sturdy fabrics..
It's extremely comfortable to use due to its angle and lightweight and the flexibility of the swivelized hose
Mr Pemberton used it on a few pieces over the past few days and I'll let him comment on his findings
I'll be with the Westpac team next week where we'll go over some of the details and we may see this fun to use, long needed, versatile tool in production within the next 2 months, hopefully.
I'm not interested in any more suggestions. It's been through the gamut with various veteran specialists has passed muster.
Cost is yet to be determined but my goal is to make it a great value just like the rest of my tools.
Oh and if you're at the experience next week stop by my/ Westpak booth if you want to see the beta version..
In regards to the new GreenGlides Upholstery Tool..
After a lot of testing and dissecting and tweaking, I've gotten to the point of me handing the tool back to Westpac and say let's run with it.
The 01 single jet sits in its own spray chamber that offers amazing over-spray control, allowing you to clean microfibers and other flat weaves in the very tidy way
There will be an optional and removable heat creating circulating system that will fix to the other end of the hideAhose for those that feel they need full truck mount heat when cleaning upholstery.
I call the Glide an "accessory" because the hand tool also works very well without it when needed such as when doing detail/crevice work, narrow areas or very rough sturdy fabrics..
It's extremely comfortable to use due to its operating angle and lightweight head along with the flexibility of the swivelized hose set up
I'm not interested in any more suggestions. It's been through the gamut with various veteran specialists and has passed muster.
Oh and if you're at the Experience next week stop by my/ Westpak booth if you want to see the beta version..
It is no secret that I'm a "Dry Tool Guy". That said, I've missed the Prochem Truck Mount Upholstery Tool for some of its versatility as a stair tool, and its effectiveness in flushing out heavily embedded oils in synthetic fiber fabrics. Mike's tool (whatever he will call it) impressed me for the following reasons: 1. Ease of use: The very flexible, 1.25" vacuum hose was so lightweight I almost didn't know it was there, and, coupled with the swivel cuff, left nearly no restrictions of movement. The stainless steel head as comfortable as the Prochem tool, but I would like to get a feel for how a lighter titanium tool would handle. 2. Lack of overspray: One of the reasons I like dry tools is that you don't get alot of overspray on adjoining areas of the fabric, or at the end of the stroke. The containing shield eliminates of the overspray, depending on the pressure you're using. You do see a little overspray at 500 psi, little or none at 200 (depending on the fabric). The glide adds a great deal to the easy use of the tool as well. Due to the spray shield, there are a few challenges in getting the tool into tight areas, but these issues become almost none existent if you remove the glide, which is easy to do. I'm glad that there will be a "window" on the tool. Due to the enclosed tool design, and the way it controls overspray, you wouldn't know how wet you are getting the fabric otherwise. I forgot that I left my machine on 500 psi, and didn't realize it until I tried to do a "mist and vac", and it ended up being a "firehose and vac"!
But I like that a lot better than hosing down end tables, floors, walls, and my pantlegs. This is the perfect upholstery cleaning tool for synthetic fiber fabrics, or if great care, pressure adjustment, and drying protocols are used, durable natural fiber fabrics.
Reactions: jeffexe
My bro, the 80's are over.. Let that dinosaur of a handtool rest in peace..
Speaking of GG, do you still make brush glides for wands?
I have to check your IP to see who is typing, you or Boyle when the sarcasm overflows...
many trusted people tested this, not a one said make it more like the plastic must touch all the time, wear out every two years, 2020 options.
yes I still sell brush glides
Doug Cox
Doug Cox
It would be hard for me to change upholstery tools after using the sapphire tool. I haven’t had to replace mine yet.
Dwain Ray
I'd give it a try. I used the steamgeni 3" upholstery tool for 40+years before i replaced it with a prochem stainless tool i got free with legends rewards points. Loved that attachment so much i bought a second one used as a spare. Next i tried the sapphire scientific plastic upholstery tool also free with legends rewards points. Hate it so much that i gave it away, went free to a good home! But I'd try this one. I have a similar looking attachment i use to clean my vans carpet but without the spray shield the angle of the head is similar to the steamgeni attachment and it's tall enough that you're not dragging your knuckles while cleaning like with the prochem and sapphire scientific tools and you don't have to be as careful laying it down like the prochem tool. If not careful to turn the head up it'll keep spraying
20230919_190103.jpg 20230919_191129.jpg 20240125_121547.jpg 20250829_162524.jpg 20250829_162456.jpg
View attachment 132393 View attachment 132394 View attachment 132395 View attachment 132396 View attachment 132397
You'd have loved a Hydrokentic tool.. Only if they made it in plastic due to the weight.. It would glide over fabric, but you still had to watch your pressure..
The spray chamber, evacuation holes along with the internal hideAhose all.do wonders for the body..
Now add aGlide, a switch to titanium and a large window and I'm positive that it's going to be a HUGE hit..
Dwain Ray
Not going to vagas this year but i hope to see this new tool sometime and if it's everything you are saying it is prehaps purchase one
So, what's the outcome if you're cleaning a heavy soiled couch with this tool or a hydrokenetic tool that needs the tool to pull backwards AND push forward while pulling the trigger since the jet is external of the vacuum chamber?
Too much water is just as bad as not enough like the SS and RTV. Any of you guys reading this, and use only the SS or RTV, you're not fully cleaning the fabric. Because it doesn't flush out the fiber enough, and is impossible to get the areas that aren't completely flat, edges and corners.
My vacuum chamber has access ports to my spray chamber...
Poochie, there is a needle valve that you can restrict the flow of water.. Say you set your pressure to 400psi, then dial in the water flow..
Then take your SS hand tool, put it in the cushion after unzipping it, and watch the flow of water go through the fabric.. To say it does not flush the fabric is asinine.. You can flood the fabric/cushion..
A lot of problems can arise when using too much water, hence the development of SS tool.. Fabric is thin and depending on the situation, you are asking for problems with too much water..
  • Wow
I suppose the good news is there's no rat clean out necessary ever!
Ok ease up, how do you expect me to ruin stuff if I can't over wet it???
Joking,
Drystroke Bob on Sam's pixel
Guy posted these on Facebook charged $3600 to clean linen and linen blend
Looks like it may have some water marks.
Getting a solid connection inside tight spaces makes tools like the SS useless. Once again, if it’s not a flat surface, you’re over wetting and or not cleaning properly. How’s this couch with all these button holes gonna get a good cleaning with a tool that can’t possibly get in those holes with it? I run into so many of these. The only time you’ll see that plastic tool in my hand is when I’m cleaning a velvet fabric. Maybe mikes new setup will do a good job on some delicate fibers to where I can get rid of mine. Do you want it?
$7million Upper scale house that is a second home for these people.. They complained about why we were more expensive than the last cleaner.. It's because we have to fix the screw-ups associated from the previous.. The cleaning is easy, if you know what your doing..
We are considered the "Fixers" for other cleaners.. If they mess it up or can't fix it.. From upholstery to carpet side match blending, sprouting tufts shearing, rug cleaning/washing, spot dyeing, etc.. You can't fix the rusting from the staples..
The Last Of The Mohicans!
