100% VLM ???
Tm- guys bring up residue from the back of the carpet oh wait, I mean re-soil from the backing of the carpet!!!
From those #9 blowers"& " 500 psi"" My bad "Sometimes I get mixed up??? Sorry
Do you even clean carpet hahaha
A sub surface tool can pull moisture out of the pad, I doubt we're pulling all the dust that gathers under the carpet with a primary secondary backing and latex glue.
But your probably sharing from personal experience, which makes me wonder if you know anything about chemistry
SteamwayPro
George
The ANGRY Steamer is PISSED OFF again
Samlam has - VLM Derangement Syndrome
Irrational reactions to people that use the VLM Method
Samlam PLEASE call this number for HELP
1-800 Anger Management
Reactions: frank fratto
frank fratto
frank fratto
A sub surface tool can pull moisture out if pad, I doubt we're pulling all the dust that gathers under the carpet with a primary secondary backing and latex glue.
But your probably sharing from personal experience, with makes me wonder if you know anything about chemistry
What's the number one complaint about a TM job??? Too WETTTTT too Longggggg.....
Second complaint a very closed second RE-SOILED.....
Doesn't take a chemist to figure that out🀭
Reactions: SteamwayPro
I use fans and last step rinse with a speed drying agent and a 4.8 blower.
Drying isnt a issue I have a problem with.
You two idiots are name calling and bashing steam cleaning.
I couldnt careless how you clean.
You haven't discovered the holy grail, you're probably broke dicks because maintenance broke you.
Hahahaha
Peroxide vlm you don't know!
Know what?
How dumb
frank fratto
frank fratto
Hahahaha
Know what?
How dumb
Sam
Nice picture GOOD job!!!✌️
4.8 not too big but she said it will get the job doneπŸ€·β€β™€οΈ
Remember, who started name-calling? I think it started years ago???
Hot water and hydrogen peroxide don't go there that's a NO-NO🀯
SteamwayPro
George
Going back to the early days ( 2012 -2019 ) when I first started experimenting with VLM VacAway had a VLM Forum and I would be the TM guy asking all the questions
Joel Hoppe answered all my questions
I used to tell him I should be sending you a check for educating me
THANK YOU Joel
It's now 2026 and I have developed my way of using the VLM Method
Completely different from the way Joel uses VLM
LESS water MORE agitation !!!
THANK YOU Joel
No tank?
Can you explain your process on residential please
SteamwayPro
George
No tank?
No tank for residential
Because I believe you need to CRB residential carpet
1 - Vacuum
2 - Spray down Detergent
3 - Scrub with CRB
4 - Extract with OP
5 - Groom
But I have considered putting a tank on my CRB
Having a tank with sprayer on my CRB would eliminate one step and make the process faster
I wouldn't be able to use it on every job but for Houses/Apartments with no furniture it would work
View: https://youtu.be/XJtMXY9OSMU
1 - Vacuum
3 - Scrub with CRB
4 - Extract with OP
5 - Groom
Do you keep a small spray bottle on hand for areas or spots that need more juice?
frank fratto
frank fratto
1 - Vacuum
3 - Scrub with CRB
4 - Extract with OP
5 - Groom
Funny i took my tank off my CRB
and all my 175.
I guess I'm forced to use dwell time!!! ✌️
SteamwayPro
George
and all my 175.
I haven't bought it. I have just considered buying it
It wouldn't work on every situation
Most of the carpets I do at my Apt Complex are spotless. It would work on them
For trashed carpet I would prespray with Worx first and then just add some from CRB on areas/spots that needed more
frank fratto
frank fratto
I'm sure if you buy it you'll find many situations to use itπŸ™‚
Heck, I could even find a situation or two to use a TM πŸ˜‚ most likely notπŸ˜‚
frank fratto
frank fratto
I think I'm going to order one of these. I had one way back, but I could never get it to prime. I think it was defective because I tefloned every thread and connection.
Same problem, I keep a ketchup mustard squirt bottle in my van full of water with the pointy cap.
Prime it out in the driveway.
