- Joined
- Oct 6, 2006
- Messages
- 117,376
Developed in conjunction with S.H.I.E.L.D and Jarvis on the planet Asgard, Flex ICE performed so well in laboratory tests that it has now replaced Thor’s hammer as his weapon of choice when fighting bloodthirsty aliens, the Hulk and carpet stains. Witnesses cite, but it has not been confirmed, that it’s probably even cooler than Tony Stark.
Bridgepoint Systems is excited to announce the release of Flex ICE extraction rinse. Flex ICE is a high performing powdered extraction rinse with a low pH that 1) out cleans all other acidic extraction agents 2) neutralizes high pH presprays 3) is highly concentrated and economical 4) is safe for your equipment and 5) Mixes in seconds with no residue that would plug up equipment. Designed to be used with any prespray, Flex ICE is especially effective at cleaning the most intimidating restaurant or apartment carpets when paired with Flex Powder. No other combo comes close to delivering the results and value carpet cleaners have come to expect from Bridgepoint Systems.
Flex ICE contains corrosion inhibitors that protect your equipment so you can use it with peace of mind. Testing actually shows that it is safer for equipment than soft water alone. It can also be used when spraying prespray in a Hydro-Force injection sprayer and actually improve the cleaning performance by adding powerful surfactants to the mix.
Enter to win one of five 6lb jars!
