- Joined
- Feb 4, 2016
- Messages
- 14,646
- Name
- Matt w.
Mullet man: have you ever used a zipper
Baconator killerI think we need more name calling. Step up your games.
That is really bad posture Dude!So I’m just doing what you see.
You're absolutely correct. I'm having to do that amateur technique because my right shoulder has something tore in the rotator cuff. So my back is taking the blow for a while until that shoulder gets better. I'm having to do shorter wand passes to keep any stress from growing on the shoulder. It really sucksThat is really bad posture Dude!
Let go of that left hand or marry a "back surgeon"
The lower back? That's what my helper was complaining about todayI know one thing for certain
I’m removing that slot glide off of mine
I was in stiff nap hell last weekend
Even adjusting it didn’t help
I thought the rear glide is supposed to be holes, not slots.I could only clean in one direction
If I adjusted the rear (slot) glide up enough to stop the bouncing, it wouldn’t extract water
I’m going back to two slot glides
I looked on mine
Yes, the slot is in the front
No wonder adjusting the rear didn’t help
Make sure you're using a stair tool for stairs. I've torn both rotator cuffs. The right one is okay now but the left is still rehabbing. Shorter wand strokes is good. Let your vacuum do the work, don't try to force the wand down.I thought the rear glide is supposed to be holes, not slots.
You won’t see me trying to copy Mikey’s Moron suggestion with trying to wand the stairs.Make sure you're using a stair tool for stairs. I've torn both rotator cuffs. The right one is okay now but the left is still rehabbing. Shorter wand strokes is good. Let your vacuum do the work, don't try to force the wand down.
Today ended up being only $71/hr. I got screwed on this one. It was originally around $100/hr, but this dumbass has been complaining about the odor. I told him next time (today) I clean it, ill include cleaning the affected areas on the back to help fix it.Are you clearing $50 an hour on this "client"?
I won’t miss this account if he finds another company. I was losing moneyYou're fired.
Congratulations
You just said I got fired and I gave you an answer as to why I don’t care if I did get fired. What’s your point ?So...?
I can’t argue on that point. I have no clue why they didn’t use a rubber type flooruses a carpeted building as a stockyard
and y'all wonder why northerners make fun of southerners???
Or concreteI can’t argue on that point. I have no clue why they didn’t use a rubber type floor
