Whats the best crevice tool? or alternative?
Acp
Cleaning Professional
Bjorn Marshall
Looking for a better set up for really getting after filtration lines, what are you guys using lately?
Acp
Bjorn Marshall
short hand tool with tech bending over, or hitting them straight on with a wand.
what do you guys use? @Mikey P
Steve Lawrence
Steve Lawrence
We have the PMF edge blasters
This is a great tool for filtration soil.
For dusting office edges I prefer a round dusting tool on the end of plastic (won't mess up computers if you touch them especially when vacuuming under desks) tubing (old Kirby tubes are best for this--very ergonomic and light).
[/QUOTE pmf makes a full length crevice tool as well as the short one. Also, check out their gum blaster wand.
J Scott W
Jeffrey Scott Warrington
Here are some options. Everyone has their favorite.
Here are some of the tools that can help.
https://interlinksupply.com/index.php?item_num=AW80A
https://interlinksupply.com/index.php?item_num=AW49
https://interlinksupply.com/index.php?item_num=AW72
There is also a nice triangle shaped brush that you can thread onto your own handle. Gets edges very easily from standing position. About $14. I could not find a link to website.
Vapor steam can give great results as well. I probably would not buy one just for filtration soil unless you encounter that a lot.
Old Coastie
Stephen
The drawback to vapor steam is that it can turn a tight yarn into an afro.
Don’t ask how I know.
Acp
Bjorn Marshall
CV-56SBG is the number for the 56" option
Its a tile tool? Im sure it works the same but just want to make sure its the right one im ordering
Old Coastie
Stephen
I have an 18” tool that I hate to use.
Wonder if it could be cannibalised and make a stand up pvc model.
Hmmm
Under $300 for the full size one. The small one works great on stairs and for the porty guys, it fits in your bucket.
Loren Egland
Loren Egland
I have a Hydro-crevice tool, but haven’t used it for many years.
Ron K
Bought the Stainless tool Interlink I think.
Then bought the Orange plastic Vac only tool.
Drilled one small hole in it and took the valve and all
and transfered it to the orange vac tool. The plastic has a
wider opening and won't scratch or mar molding.
Reactions: Acp
Acp
Bjorn Marshall
nice good idea.. the one typical problem with filtration lines is they tend to be in the homes with cheap MDF baseboards. Some of the tract homes are getting better but the ones built in the late 90s are the worst.
Steve Lawrence
Steve Lawrence
I can't find it but there is a steam tool with a 3-4" head that we got just for filtration soil. We talked about it here last spring I think. There is a link in that thread with the tool. about $220.
icleancarpetz
Rafael Samson
Filtration soil is difficult to remove and not always responsive to whatever tool and chem used. Results vary. I hate dealing with it. I often advice it may or may not come clean. Whenever I see it, immediately inform it may or may not come out or so so results.
If customer insist to remove, I then try my magic. If they like the results, I tell them it’s going to cost $100 a room (depending on the size). They quickly change their minds and opt for the normal cleaning. $100 per room or replace the carpet...”What would you like to do ma’am?” (Replacement will cost much more but is often not within their budget nor is $100 a room to clean just filtration soil, so we are both happy to meet in the middle, which is...they ain’t Paying all that money for filtration removal and I get to grab the easier money instead of busting my azz trying to be a filtration soil hero)
These days, I chase after easier doughnuts to make.
The problem with filtration soiling is, even if you can improve it, you haven't solved the problem and it's going to come back. Even worse if you have left a lot of residue behind. Filtration products often have blends of non volatile solvents and foaming agents that are difficult to rinse.
Andy
Doesn't Matter
Can't imagine why you wouldn't want to use that. I have to say their are some really excellent salesmen in this industry.
Acp
Bjorn Marshall
its really not that hard to remove unless you have some crazy type of soil in your area idk. We use a grout cleaner mixed in a pump sprayer, wipes it out very easily.
only real issue is cheap homes with MDF baseboards or even worse stairwells with str8 drywall no trim at all
Acp
Bjorn Marshall
then theres this... $1,000,000 townhouse, 25x25ft lot size, and this is the build quality of some lol should be a crime
my foot could have almost fit in there
It all depends on how long the filtration has been a problem and what sources of pollution you have in the area. I have some that come right out but the majority is so so. Most of the time, I just prespray and rinse unless they're prepared to pay me for the attempt
