What causes this?
Josh Almanza
Cleaning Professional
Josh Almanza
Noticed yesterday when I would squeeze the trigger there was a short delay in the water coming out of my wand. Also noticed it when I tried squeezing the trigger on the hydro force...you guys know what may be causing this?
Mark Saiger
Mr Happy!
Mark Saiger
Check connector on end of your high pressure hose first and maybe replace
Reactions: Josh Almanza
steve_64
Valves need replacing?
They may be leaking allowing air into
Try upholstery tool and stair tool if all tools do it could be a outbound filter on machine?
only time I've noticed such in more than one tool, was when there was slight air leak in draw side of plumbing
Or when running temps in the 260+ side ATM and that momentary "hisss" before the "tear" sound wand spray makes at 230+ATW
