WD-40 it's not just for grease spots on carpet anymore..
*The uses shown and described for WD-40 Multi-Use Product were provided to WD-40 Company by the users themselves. These uses haven’t been tested by WD-40 Company and do not constitute a recommendation of suggestion for use by WD-40 Company. Common sense should be exercised whenever using WD-40 Company products. Always follow the instructions and take heed of any warnings printed on the packaging.
Reactions: Jim Pemberton
Binghamton,New York
It probably won't remove them, only hide them.
We used WD-40 in my laundromat for polishing over stainless steel polish for hiding softener stains and hard water deposit stains.
Numero Uno
Ma
Caesar
Any reputable window supply house will sell you the correct easiest stuff at a much lower price...Common sense people...You have water stains which absorbed into the glass...You need correct agent to dissolve and neutralize rocket science .An accelerate performance with heated water ...Allow dwell then agitate then rerinse 2 times clear or distilled . Abrasives which will not scratch can be used ... as in a Scotch type pad or extremely fine sand paper wetted in small circular motions .Also a razor going only one way when wet also helps to shave minerals off surface...The rest is inside needing to rinse out...But Jim P said it best ever since social media arrived...The Duh' crowd is in force on advice.
