VCT Help
jwfoulk12
Justin Foulk
My problem was stripper splashing up on the baseboard from the 175. Then when u went to wipe it off it took the paint.
glenboy
MACOMB MI
GLEN
I apply stripper with a doodle pad and pole scrub all the edges...stay a machine width from baseboard...I keep heavy steel wool.and several scrapers and brass scrub brushes..maybe even some cans of baseboard stripper
Sent from my SAMSUNG-SM-N900A using Tapatalk
Reactions: JS41035
J
JS41035
Gotta make sure your strip pad is centered. Helps with splash. And when I see painted baseboard I let them know it could be scuffed a bit. Don't rely on masking tape. Stripper will still soak through it if your sloppy. If you have a a helper I've used a flat Sheetrock knockdown tool to protect the edges as you go.
Lonny
Find some border edging from Home Depot, attach it to your 175 so that it acts as a splash guard.
Reactions: jwfoulk12
