- Joined
- Oct 6, 2006
- Messages
- 117,395
I still get dripping after I do that. Does that mean the trigger is wore out?I use the white magic set up with the wand using a female and the supply a male with a shut off. Just clear the wand and disc connect the supply line and no dripping. Yea not a lot of fun but less water on all the tile floors. jz.
For me yes. But even a new valve only lasts a few weeks before the drip starts again. I just try and keep it minimal.I still get dripping after I do that. Does that mean the trigger is wore out?
I've vaccd them up out of my pocket to many times switching tools.Spotting towel in my pocket at all times.
You have to clear the water from the wand after the line is removed into the carpet give it a little time then you can move to the next room.I still get dripping after I do that. Does that mean the trigger is wore out?
When I am done with a room and need to cross a hard surface floor to get to the next one, I turn off my valve and do a few dry passes. The vibration shakes out the solution still in your manifold and line.You have to clear the water from the wand after the line is removed into the carpet give it a little time then you can move to the next room.
If you want to learn more he’ll be teaching at the SC Mikey’s Fest.Ok Chandler
I prefer buttons.I use a zipper!!
I often wonder.never understood how/why some of you boners don't cover hard surfaces
..like the blow 'n go hacks
My water runs about 210- 240 hard not to have leaking due to the heat just keep changing things and maybe no leaks for a short time ?When I am done with a room and need to cross a hard surface floor to get to the next one, I turn off my valve and do a few dry passes. The vibration shakes out the solution still in your manifold and line.
I bring in drop sheets but can't always cover everything.never understood how/why some of you boners don't cover hard surfaces
That’s why you keep popping em.I prefer buttons.
I'm a hack.
