Steamin Deamon
jstucky
Jordan Stucky
Borrowed from local cleaner to try out. Using at movie theater and possibly restuaurant? Advice? Tips? Pros and cons of it? Works ok with cold water because using that much water no where will supply enough hot water? Some have said really hot water will mess up pump or machine somehow?? Help with eliminating wick back flushing so much out??...Can any wand be hooked up to it for stairs??
jstucky
Jordan Stucky
Yes but can I hook ANY wand up to it? and not just the wand made by steamin deamon?
Scott S.
PA
Scott
you should talk to rob lyon. he loves the steamin demon. why not use warm water to start with. some heat is better than no heat.
