Sacrificial anode in aluminum recovery tank- Will it prevent corrosion. Does it work?
ruff
San Francisco, CA
Ofer Kolton
I am getting confused here.
Will a sacrificial anode in an aluminum recovery tank help preventing or reducing corrosion?
Some say that it will only help in fresh water tank, some say that it will help in recovery tank.
Anybody knows?
Oh hell now we're into sacrifices? I knew it was bound to come to this. :p
Not sure. ??? How long has your current one done before it had an issue?
Can they rino line the inside of a tank? I wonder if it would help?
Reactions: ruff
dgardner
Phoenix, AZ
Dan Gardner
I don't know for sure, but in the marine environment I know sacrificial anodes are used both in fresh water and salt water. I imagine electrolysis happens in the recovery tank as well.
I do know that for the anode to work it must be fastened (electrically bonded) to the aluminum, it's not something you can just toss in the bottom of the tank.
dgardner
Phoenix, AZ
Dan Gardner
The problem with tank coatings is they must be perfect. One pinhole and liquid seeps under the lining and gets trapped there, which is worse than no lining at all. There are companies that specialize in tank coatings, but it is a very meticulous, expensive process involving careful surface prep and usually several coats of an expensive coating.
A decade or more ago we used fiber rinse exclusively and we would get barnacles building up in the aluminum waste tanks. It only happened with the acid rinses, nothing since.
Gotcha!
dgardner
Phoenix, AZ
Dan Gardner
That makes sense. An anode would help electrolysis in the recovery tank, but wouldn't stop direct chemical attack.
Reactions: Shawn Forsythe
Hagopian uses Butlers and Butler has all stainless waste and fresh tanks
Actually Steam Genies made the best stainless tank ever...over the wheel well saved way more space....with a stupidly simple waste tank filter
i jus turned down two Steam Genies (cheep) cuz they didn't come wit a waste tank....
GeneMiller
Boca Raton
gene miller
Zinc, aluminum and magnesium are all used as sacrificial anodes. Magnesium would work best for an aluminum tank. Never used one,always had aluminum and never had any problems. Don't suck up coins, pennies stuck to the bottom of your tank can cause some problems.
Gene
