PMF handtool tips, any plugging issues?
Cleaning Professional
those things, found in PMF internal uph and tile tools, ever plug them?
how did you unplug them?
I take a strand from my stainless steel carding brush and use it like a tee-jet cleaner, then blow it out with an air compressor. I use a 100 mesh inline filter at the quick connect. Very little problems with clogging.
Reactions: JohnHawkP
Steve Lawrence
Steve Lawrence
Ditto. The 100 mesh in-line filter is a must for this tool and most others.
If you go through all the trouble to remove that little thing, you might as well put a new one on
Sometimes you can blow it clear with 1500 psi blast
Hold trigger valve open when you engage the pump so don't blowthe 800psi valve
If that doesn't pop it, poke and blow simultaneously
I used craft store beading needles
Theycan be found much thinner than sewing needles
Poke n blow
If it clogs again shortly, pull the jet and flush the tool
LTA
Reactions: Steve Lawrence
Old Coastie
Stephen
Larry I just cannot avoid the double Nintendo...
Tell the clue ball to flush his line at start up of eveye job and fouled jets will be thing of the past
CC'ers are stoopit
you can lead them to water, but still won't know how to wipe their damn bum
LTA
NobleCarpetCleaners
Noble Carpet Cleaners
yep, I used a sewing needle and air compressor, then I installed #100 mesh filter inline, but then I threw it the f.. away for better tools
