older pro-chem wand,,,jet size ?
allen
i have an older pro-chem wand,,4 jets, that was included in my recent tm purchase,,whats your opinion on using new 02 jets with this wand
John Olson
Orem UT
John Olson
Hi Allen. I don't think you need more then 95015's going up to 02's won't hurt anything except you might see some heat loss with the 9100. It will cost you about 40 bucks to change them out if you want to see how they'll work for you.
allen
thanks john,,i have some new 02's and the ones in the wand are 015's,,,but real old,,spray pattern looks bad, should i use the 02's or get 015's
If you have the 02's use them.. any small amount in heat loss will be made up in more thermal energy transfer to the carpet. Give it a try.
dealtimeman
Everyday is Saturday.
Fort Worth , Texas
Michael
switch out the 1.5 to 2 and notice the difference. you should get a glide from lisa at greenglides if you dont have one on the wand already, to aid in the recovery of the bump up in water.
KevinD
Binghamton,New York
Kevin Dumas
The pain in the ass factor of keeping .01 and .015 jets clog free make me run nothing smaller than a .02 jet.
Try them. Your water might even be hotter at the wand with the 02's.
It will get there faster with less cool down along the way.
