I need an electric sprayer for upholstery
SteamwayPro
USA
George
I do a lot of Upholstery. Multi Sprayer is the BEST
I have electric and cordless battery Multi Sprayers. Electric is always in my van and used as a backup. It has to be 20 years old
Battery is what I use most of the time. I've had two. First one lasted about 5 years.
Easy to change jets and jugs
Multi Sprayer is also used for Carpet/Fabric Protector and Deodorizers
Dwain Ray
I built mine . Using a longgray 1.5 gal stainless pump up a kleanrite inline quick connect filter 10' hose and gunjet off my hydroforce sprayer and a rechargeable air compressor from Costco. The compressor in in a bag i bought from patriot sprayers. They sell a sprayer that uses a paintball gun co2 bottle to maintain pressure. been using it for yearsno problems even have a dedicated charging port built into my truck to keep it charged i like the patriot sprayers idea of constant pressure but there's no place close for me to recharge the co2 cylinders otherwise i would have bought 1 of them with a spare bottle and modified the hose. A friend of mine stains concrete and uses um and said that the patriot sprayers are expensive but last forever with little or no maintenance . I got about 200.00 in mine
20230117_103249.jpg 20230117_103116.jpg 20230117_103131.jpg 20230117_103156.jpg 20230117_102700.jpg 20230117_102641.jpg 20210226_235114.jpg 20210106_162829.jpg 20250418_084532.jpg 20250418_084521.jpg Screenshot_20250607_113017_Chrome.jpg Screenshot_20250607_112917_Chrome.jpg 20230117_102917.jpg 20230209_113317.jpg
View attachment 131254 View attachment 131255 View attachment 131256 View attachment 131257 View attachment 131259 View attachment 131260 View attachment 131262 View attachment 131263 View attachment 131264 View attachment 131265 View attachment 131266 View attachment 131267 View attachment 131258 View attachment 131261
I've got a bunch of co2 tanks from my paintball years, and I can fill it myself also. That's a good idea
Dwain Ray
Thanks hope it works for ya. I would like the constant pressure that co2 would allow. As it is now i set the pressure at 60psi and when it drops to around 40 i have to hit the button on the air compressor. Look up patriot sprayers you can just buythe pressure regulator and bag and hang on any sprayer that has a Schrader and relief valve like the longgray.
Does the corded multi-sprayer spray more powerfully than the battery powered multi-sprayer, or are they about the same with output?
I've never used the battery powered one. Not a fan of most battery powered equipment. I find it's a pain to be charging or making sure your device is charged. Corded always works for me.
Reactions: Bryce C
they live
Michigan
Steve
I don't use battery sprayers.
Mr Brightside
Southern Cali
Jay Wags
it sounds like you guys spray more than me I use a normal trigger sprayer from Lowe’s but try to use as little as possible on upholstery just rinse with all fiber and heat
Dwain Ray
Cool, are you using the wand and jet that came with it or swapping it out for longer hose and tee or vee jet?
Dwain Ray
yeah, im not too impressed with the jet on it, s I'll see how I can switch it to a v jet
Im sure you can do it with the right adapters. Youll need a metric &sae thread pitch guage to find out what you're adapting from and to for me it was a couple of brass adapters and the hose and gunjet off my hydroforce sprayer and I was done( the ebay adapter pics were from 2 different things i adapted. But sent to.give ya the idea)(i used the hose barb one on my sprayer)
Screenshot_20250615_095526_Gallery.jpg Screenshot_20250615_095408_eBay.jpg Screenshot_20250615_095339_eBay.jpg
Dwain Ray
I agree, id have one if i didn't already have the stainless sprayer. I had already converted it to the 10' hose, inline filter and metal gunjet. To add the bag and compressor it was only 60 bucks more. I wish the compressor had a setting to maintain a set pressure instead of having to start it when the pressure runs low . But i do like the fact that if anything happens to the compressor i can still pump it up manually . And in the unlikely event that i have a low tire on the job i can pump it up with the compressor too. Does your van have a 110v outlet for charging? Mine has one on the dash. It comes in handy when i have to use my milwaukee m12 led light tower. I can keep a battery in the charger ready to go i also built in a usb&12v charging ports into my back cabinet
20220322_104506.jpg 20220217_144500.jpg 20220522_105102.jpg Screenshot_20250615_115836_Gallery.jpg 20220520_153312.jpg
Dwain Ray
I stopped using electric sprayer on upholstery and just switched to pump sprayer
Mine is both, ya might say best of both worlds or built with manual backup.I can use the compressor and if it for some reason doesn't work it has a stainless steel hand pump and i can just use that and continue working
Reactions: Bryce C
