How much water are you using?
Swani
Today I cleaned around 1500 sq ft of carpet with my 6 jet, 9 flow at 600psi and used around 55 gal. Of water. Is this close to the amount of water you guys are using?
You would notice those things if you use 50%
capacity in your first small house Moron!
Reactions: hogjowl
Swani
Id probably be at about 85-95 gallons at 400 psi and 6 flo - same proceedure except with a CRB. Maybe Im doing something wrong.
What machine are you running? This was wide open areas with no furniture. There was no idle time so the machine never bypassed water.
