Gym rubber mats..
I've sprayed them and wanded them in the past and I'm wondering if there's some magic solution that I could get the foot stench out and use the Phoenix machine instead, which would go way way way way way quicker
"way wy way quicker"
next thing you know, you'll be cimexing res
oh yeah, never mind....
sure not an expUrt.....but don't know if your magic bonnets are doing much more than the dude with a mop 'n bucket of sanitizing solution
smearing sweat around is just one step above "blood clean-up" , Forest
Hack Attack
Dan
1st step of cleaning is always bulk removal of soiling and contaminants not magic fufu juice..
however, this companies products have interested me for awhile
Microban?
That works for "CP" (cootie protection)
and if not mistaken, mandated antimicrobial solution in schools
But I've always found a shower to best remove sweaty stAnk compared to a bird bath with towels
Use a powrflite multiwash. Spray down your prespray of choice, extract with the multiwash using neutral cleaner then spray with benefect.
randy
Randy
On gyms we Spray Spartan consume (also a great prespray for pre-encap cleaning on carpet) and run the vibe for rinse with straight water rinse. A 15-20 minute dwell time is a must for the mats.
Jeff T
My daughters gymnastics coach asked if I could clean the sponge carpeted ‘runners’ in the gym..
They are 18’ wide, by 80’ long.... there are 6 of them total...
That’s 1440 sqft each, X 6= 8640sqft...
They asked if I could clean ALL OF THEM FOR 200$....
I told them the best I can do is between 1800-2000$ for the job....
Uh, I don’t clean for 2.5 CENTS A SQFT.... sorry...
randy
Randy
You mean that you use a wet pad to mop up the Sparten stuff, right?
Yep spray consume through machine and pad it. Then rinse with water. The gym I do took 10 pads for the whole running track and the padded area I think they use for contact sports of some sort. A rotowash is better but unless you have a lot of use for it just HACK 😉 it out with OP or rotary.
