Electric Hose Reel RPM?
AshleyMckendree
Versailles ky
Ashley Mckendree
Im building a few Electric Vac Reels, and am in the process of getting pulleys... how fast do most Power Reels spin?
100 RPM? Less?
Jimbo
I'm guessing a lot less, Ashley...I will count the rpms on my Rokan Electric
Jimbo
18.3 revolutions in 30 seconds...so 36.6 RPM
Are you going to sell those Ashley? Might be a market.- Jim
AshleyMckendree
Versailles ky
Ashley Mckendree
Thanks Jim!
At the Moment I'm building them for my trucks, but I'm always open to squeezing a few bucks out of the suckers on this board :twisted:
floorguy
Utah
Doug
i want detailed pics.....
so i can get my mechanic to modify my reel
Able 1
Wi
Keith
Mine spins at around 90rpm has has a good amount of torque... I'm going to start building another one soon myself... Are you going to use a belt or chain to drive it? My last other one is chain driven and I have had no problems with it. I would suggest using a breaker rather then a fuse even though it is a little more pricey.
Able 1
Wi
Keith
Lee Stockwell said:
90 rpm? Surely not the reel itself, perhaps the motor?.
Yes the reel itself with no load probably 75rpm under load... :twisted:
Benton KY USA
Able 1 said:
[quote="Lee Stockwell":3o2lmi29]90 rpm? Surely not the reel itself, perhaps the motor?.
Yes the reel itself with no load probably 75rpm under load... :twisted:[/quote:3o2lmi29]
Would wrap up 100' of hose in about 8 seconds.
Would also take a few minutes to clean up the mess that would cause.
Able 1
Wi
Keith
Lee Stockwell said:
[quote="Able 1":1m11mmhi][quote="Lee Stockwell":1m11mmhi]90 rpm? Surely not the reel itself, perhaps the motor?.
Yes the reel itself with no load probably 75rpm under load... :twisted:[/quote:1m11mmhi]
Would also take a few minutes to clean up the mess that would cause.[/quote:1m11mmhi]
Time IS money Lee as you know... I would say 8 seconds for 100ft is about right. Not sure what mess you are talking about though? It dosen't make.any "mess".
Art Kelley
Clawson,mi
That is one of the joys of modern day carpet cleaning. My electric reel winds up each 50' hose length at ten seconds per. Really nice when your arms are beat to a pulp at the end of a job.
Erik
Michigan
Erik
I will time the reel on my 777, i think it's pretty fast. It will definitely pull your feet out from underya! thathurts
Erik
Michigan
Erik
I had 400' on the chain driven hose reel on my Vortex 777 & it pulled in the last 100' in 12.5 seconds, it ran at 66 RPM's.
Also, I had 400' on the gear driven hose reel on my Vortex 6008 & it pulled in the last 100' in 19.5 seconds, it ran at 46 RPM's.
I can measure the sprockets on the chain drive, if you want.
No one was injured from flying cuffs conducting these test. shiteatinggrin
