cat pump check valves............
I am looking for a set of check valves that support the high and low pressures switches on my thermalwave.......
normal check valves have a raised tip on the top of them........if you have high and low pressure switches.then you need the check valves with a flat surface and a small hole on the top......
spotman123
New york
Wayne foster
Jim, when I changed mine out I just sanded down the tip and drilled a small hole in it. Not sure you can buy them that way? Itoo would be curious...
