BOSS hose was mytee clogged..
No idea what was in there after only 3 jobs but I had to get resourceful to get the job done...
Actually I hooked the new 1/4 coil hose up to the Vortex and blew it the * out but that is one funny option..
Ron Lippold
same here mikey release the trigger and it would keep spraying got her fixed boy does that thing put out the juice
I think the problem maybe the new 1/th hose they swapped form the 3/8ths.
If you run the pump dry there is not enough airflow to suck new juice.
Ron Lippold
i ended up pulling a little piece of plastic out of the tip
C
Chads
Yall suck you Vortex guys always get all the cool tools I want one now just cant afford it yet. Dammit now I have to wait and dream thanks for rubbing it in. :x
A Tee jet with filter in the tip would make that all an afterthought. Then you could have a filter/checkvalve and not have any drips either.
Wouldn't be able to use your sexy wand silo though, would need a bigger tube.
Jeremy
Jeremy
Probably just as good as a community college engineering degree...
In other words Brevic is out in shed designing a new and unimproved Booster box for the Boss.
Lyman
Lyman
Two days using it so far. It is NO hydroforce, but does its job.
Concerns- Wand components, need improving
Tube wands sits in, fills with rusty prespray
Smaller jet for uphostery
Sorry guys for the honesty.
