Badly stained tile.
I thought this tile would clean up with ease. I mixed stripper (light), tile cleaner, and sp in hot water, sprayed down, scrubed for thirty minutes, and cleaned at 1100 psi. There was an improvement but it is still stained. I learned the pervious owner used old english wood floor cleaner on it. I am working on it right now. I sprayed some Viper Renew down and I will give it 30 minutes dwell before I scrub and rinse again. I am hopeful this wll work. Color seal is not an option. Well that might work, but the grout in a lot of areas is the same height as the tile or even above the tile. We will find out just how good Renew is.
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Sounds like a lost cause, how did you determine it would clean up easy ?
Omg. I can already tell a huge difference. I gave the acid 45 min to work. I think this floor is going to look brand new.
I'm sold.
This floor (mine) was stained. I thought there was no hope.
The acid kicked its azz. It looks brand new.
