2.5 hose
Ne
Who has the best price on a 50 footer vacuum hose?
Rex Tyus
I don't know about the price question. But don't forget that 2.5" hose will be worthless without an intake upgrade. You will be amazed at the performance increase on that Cleanco. Seriously. It is shocking.
I respectfully disagree, Rex. By simply adding one section of 2.5 inch hose to my stock TCS unit, with it's "2 inch" tank opening that is really about 1-3/4 inches in diameter, I saw an improvement in the performance of my machine. Of course, adding a true 2.5 inch opening to my tank took it to a whole new level, and I recommend that, but he can just add the one section and notice a difference.
Ne
I will add the 2.5 port and keep a standard 2 inch port for short runs.
I didn't see any 2.5 at wintrax or dultmeires.
Mike Draper
It's always a good Idea to buy the cheap shit cuz it last 1/3 as long as the good stuff and then you can have the enjoyment of buying it twice and spending even more money to do it the right way the second time around... :roll: Just talk to Greenie and buy the good stuff! It'll last you forever. It doesn't wear out like solution line does.
Rex Tyus
I see your point. However the cleanco 56 is maxing out its recommended lift capacity trying to feed that 56 blower through the puny little ridgid 2" 90. If he had to choose it would be better to use the sweeping 2.5" 90 and reduce down to 2" hose. A 56 driven by an AC clutch is wasting alot of cfm through the vac relief with the stock setting. That ridgid 2" 90 is a lift consumption device. The Cleanco 56 only has 10 to 12" to safely play with.
Rex Tyus
Save yourself some time and money. Once you see the difference you will NOT EVER want to run that unit with a 2" hose run again. If you like just keep a short 25' section of 2.5" for the short runs. Get the 2 port 2.5" manifold. TRUST ME brother. I would not mislead you on this.
tman7
Tacoma, WA
Tony Gillihan
Is there any noticible difference between running a y coupler off of two standard hose ports and a 2.5 inch opening ?
Jimbo, get the clean sweep 2.5 elbow from the Green trinket salesman.
Mount it to your waste tank lid if possible and watch Cleancold come ALIVE
buy a 2.5 ro 2" reducer from GreenJaun .
You need one anyway for the 2" whip.
we run a short piece (6-8ft) of 2.5" and 75ft of 2"
The adapter is used there.
For runs over 75ft, we run 50ft of 2.5 and use the adapter to connect at the end of 50
either way, you'll need an adapter...so get one to use with long or short runs
Rex Tyus
Not really. The 2.5" port is just easier to work with. Plus by the time you buy a 2 2" to 2.5" Y you could have just installed the 2.5" upgrade from the Green one
Cheapest route,get a y and just use another 50' of 2",you get more airflow,and contrary to some here,it is not real difficult to hook up another 50 footer.
Rex Tyus
It is not "difficult" it is just less efficient. The mathmatical advantage a 2 2" hose set up has is negated by the ridged 90s and the Y connection itself. There is no measureable difference with either set up. Unless you decide as many have to run 2.5" all the way into the home and use a 12' 2" lead hose. Then the 2.5" surpasses. But I don't won't to get sucked into this tired old debate.
Jimmy is just looking for the best place to buy his hose. The decision to upgrade appears to have been made.
Rex Tyus said:
[quote="K. P.":3p0iyqs4]Cheapest route,get a y and just use another 50' of 2",you get more airflow,and contrary to some here,it is not real difficult to hook up another 50 footer.
Jimmy is just looking for the best place to buy his hose. The decision to upgrade appears to have been made.[/quote:3p0iyqs4]
Jimmy is looking for the "cheapest" place to buy some hose,I gave him a cheap alternative with comparable results,and I am not Cooper,cause if I was I would call you D.A. and told you I was going to run 2 2" all the way with a 10" whip of 2" and Greenie sells trinkets and Mikey is gay and bla bla bla and on and on and on and f#$#@ing on.
floorguy
Utah
Doug
you mean like this???
This is the tank set up i have....so just adding a 2.5" is not viable
makes a HUGE difference
