Westpak spinner?
Cleantechsk
western Canada
Dustin
Sure don't hear about these too often? Curious if anyone here has one and how to they compare to the turbo tools? I have only used the sx-12 and took a new sx15 on a demo that had a bad bearing.
Thanks
Stainless steel vacuum swivel for trouble free service. • Double seal stainless vacuum swivel with 3 bearings on each side. • Low profile, lowest in the industry, less tan 3" tall. • T-style handle for easy control. • All stainless steel construction. • 1 3/4" flow path for maximum flow. • High pressure all stainless steel valve. • Inlet for 2" hose, will also fit 1.5" hose cuff. • Stainless steel angle valve. • Rotating vacuum bypass near handle for ease of use. • Replaceable floor ring allows use of various floor rings and brushes. • Balanced spin jets for high pressure cleaning. • Vacuum slots at the edge to remove water and debris. • High pressure double bearing and ceramic seal assembly. • Splashguard. • Nozzle 0502 (2ea). • 2.0" Diameter Tube. • 14" Head Width. • 2.75" Head Height. • 52" Height.
dealtimeman
Everyday is Saturday.
Fort Worth , Texas
Michael
Don't mess around with that( please keep n mind I have never owned one or used one). If you get a turbo hybrid and one of these side by side I would assume the turbo hybrid would outperform it and outlast it.
Why don't you buy a turbo hybrid?
