Water feed pump
Wi
Keith
That looks like the one I have... I paid my disty about 150.00. They might have smelled blood though.
XTREME1
Ma
Greg Crowley
I had problems with several flojet pumps hooked to my fresh water tank now I have a bilge pump I got from a marine store and it is awesome. No more problems 3 year warranty
Shawn Forsythe
Some pumps use an internal bypass that maintains a fixed pressure, some use a pressure switch, and others have neither.
If the pump has no means for maintaining a certain pressure without deadheading, you need to either add one, or use a regulator. If you don't, the pump motor will fail in just a few moments after overheating.
And yes, as already noted, the voltage should be taken into considertion. You probbly want a 12 volt DC version for your Truckmount supply pump.
