THANK YOU TO EVERYONE
ChuckR
I would like to thank everyone for posting messages about my el diablo without your support it might not have turned out the way it did. Hopefully i will be swapping the blower out in a week or so. Everything else with the machine is running top notch.
Thanks Again
Chuck Riley
T
The Magician
How is the heating system working.? You said u had to cut wires and sensors. Make them fix that too.
ChuckR
Heat system works good now. The wires are in the inverter, distributor is going to look at that also it only overheats when its hot out so i have a couple of months to figure that out. I run a small commercial jan fan to keep it cool but it can be a pita at times
KevinD
Binghamton,New York
Kevin Dumas
Might want to take the "Junko" out of your profile.
Whoever is installing the blower, make sure the coupler alignment is perfect or there is a possibility for extreme vibration resulting in blown couplers or worse, back to where you started with the blower bolts and seals coming loose. Hope they are paying your disty to do it.
Good luck.
