Service Advisory for all TM
GeneMiller
Boca Raton
gene miller
I replaced my vacuum gauge today because it was looking a little yellow and worn out. Boy was I surprised when I hooked it up and it read 20hg. I went back inside to get another one just to be sure and it read the same thing. The old one was reading 15hg. Might be something worth testing.
gene
gene
CK and see if the vent cap or rubber tip is cut open on the top of the gauge.
KevinD
Binghamton,New York
Kevin Dumas
[/quote]CK and see if the vent cap or rubber tip is cut open on the top of the gauge.[/quote]
Well don't just leave it at that.
Is it suppose to be and why?
Is it suppose to be and why?[/quote]
Sorry , after you install the gauge you cut the rubber tip off so it will vent.
LES
LES
Maybe that's why my gauge reads 15"-17". Cut it completely off or poke a hole to let it vent a little?
GeneMiller
Boca Raton
gene miller
I had the original from the factory and the top was not cut that I could tell but the new one has a little metal piece you pull up.
gene
