Sapphire Upholstery Tool
Noble Carpet Cleaners
Been hauling it in each and every job side by side with the Hydrokinetic. Found they compliment one another. Sapphire for tight fitting areas; arm tops, front of arms, lots of backs and sides. Also found turning up the flow waaay beyond what the cheesy manual says is "normal". 275 to 350 psi at the truck seems to be a sweet spot, and perfect for the Hydro as well.
The Hydro is much faster in the rinse in wide open loose fitting really soiled fabric. And switching back and forth is fast and easy. Same pressure and right into the same 2" main cuff of my main vac hose. Don't miss my Prochem, or any of my PMF tools. The time I wasted in the past chasing over spray spritzing everywhere makes me angry. But now I focus on production and my two new best friends on upholstery.
Ann Arbor
Steve Lawrence
Good idea with the 2 tools. I would wye off the solution hose so that they're both ready to go by just switch the vacuum hose.
