Auction Rotovac XL Bonus Offer
Up for grabs is a "Factory Refurbished" Rotovac XL. (.5 horse model)
Your choice of any two heads, choose HERE---- http://carpet-cleaning-equipment.net/360xl-heads-pads.shtml
Works with most Portable Extractors or Truck Mounts
The Rotovac 360XL is air flow calibrated to work with most portable extractors or any truck mount extractor. Give your business a boost and your back a break by hooking up the 360XL to your existing portable or truck mount.
  • Features:
  • Cleans better with less effort and leaves carpet drier than a wand
  • Large 15" wide cleaning head
  • High torque motor with tough helical reduction gearing
  • Patented Swoop Glide™ vacuum ports
  • Telescoping handle for compact storage
  • 144 RPM
  • 55 lbs (without cleaning head) 68 with head
  • Rugged cast aluminum frame
  • 2" clear view tube
  • Unique marketing tool, land new accounts and generate referral business
Free shipping to the Lower 48!
Starting bid is $1500 w/ a $25 minimum increment.
$2700 retail value plus shipping
Auction ends 6/6/17 at 6PM PST
Hey, I didn't spend $3600 for 2 fricken wands
And you still need something to loosen the dirt from the carpet
Rotovac
Redmond, WA
Nick
Non adjustable rpm
Ace that GEeAus you can have it
Mike is 100% right, there is no need for adjustable rpm. Its a soft start motor and it runs at 144 rpm, it won't get away from you. There is no reason to have adjustable speed at this rpm.
Anyone can upgrade to the 3/4 hp motor any time. You do not need the 3/4 hp motor unless you have a setup like Mike with a Vortex and brush head on residential.
That said, if you want the 3/4, we can upgrade it after you win the auction.
