Pressure Washing
Don336
Raleigh
DJ Settle
I've got a gas station lined up to clean sidewalks and pump areas. I have a cold water 3000 psi pressure with a spinner attachment. Can anyone provide some insight on the best products and process? I've been doing some residential with Krud Kutter chems but I'm sure this is no match for the gas station.
cape coral fl.
jack zerkie
Be careful with what you use not going into the sewer system. A truckmount would be okay to recover the products you use for the cleaning. Open flat areas are not easy, The spinner and pressure is okay but not the run off. jz.
Good point by Jacki
Do you have to contain the mess?
Did they contact you?
I would guess that there are services that specialize in gas stations, much like range hood cleaners.
