Pressure problems
Magic Touch
Austin Texas
Byron
Years of Experience
15
Role
Business Owner
Hi guys! I picked up a unit with Prochem Legend GT. It was working pretty ok but now the pressure starts off strong but ag=fter a bout 5 minutes it starts to flutter and dies down. Im pretty sure the last owner did not do great maint on it. Any ideas what might
be the issue?
Thanks!
Dwain Ray
be the issue?
Thanks!
Go fish! You've given absolutely no information to help you, so after taking a moment to think about your problem, i have come to the conclusion "it is broken " air in pump?? Worn-out pump plunger seals?? Cracked or plugged inlet hose?? Clogged filter screen ??Chemical pump?? Chemical meter air leaks/ chemical eaten fittings?? Low water in waterbox?? Broken or damaged brass fittings?? Unloader failure?? Your gunna need to give a little more info to get a better answer. I never had kids so when a baby cries i have no idea whats wrong i can check the diapers, look for bleeding and feed um but till they can talk and say where it hurts thats about all i can do
air in pump??
Chemical pump??
Unloader failure??
Fixed it for you DR....:lol:
Magic Touch
Austin Texas
Byron
Years of Experience
15
Role
Business Owner
air in pump?? Not sure...how do I check Pump was super low on oil(thats how I bought it not sure how long it had been run almost dry
Worn-out pump plunger seals?? See above
Cracked or plugged inlet hose?? Inlet hose seemed ok
Clogged filter screen ?? Screens clean
Chemical pump?? Person had not used chem injection in about 2 years
Chemical meter air leaks/ chemical eaten fittings?? Its off and jug has water in it jsut in case
Low water in waterbox?? BOx has water
Broken or damaged brass fittings?? Fitting look ok Dont see any cracks or leaks
Unloader failure?? Replaced the Pressure Regulator today....no effect
What do you think Doc?
Magic Touch
Austin Texas
Byron
Years of Experience
15
Role
Business Owner
Also, at idle it seems ok but when idled up to speed it only work for a few minutes then starts to have good pressure first trigger squeeze then then pressure drops quite a bit
you think the bypass may be an issue?
Dwain Ray
Without seeing it . I would check and make sure chemical system primes if it primes and no bubbles in chemical meter and little indicator stays down at zero afterwards, next i would prime the pump running it outa oil isn't a good sign but if the pump comes up to pressure Without pulsating but drops when you squeeze the trigger eighter you have seal damage inside the pump or the unloader is the problem. If the pump fails to come up to pressure you might get lucky and just have a stuck check valve in your pump and pulling out the 6 check valves (3 inlet 3 outlet) and cleaning them up might do the trick. When these plunger pumps set for a time the valves can get stuck and just need cleaning.
they live
Michigan
Steve
Have you read "does this flow make sense" thread a little below in this room?
Does the pressure drop on the gage or just at the wand?
Fittings could be wore out where they push each other open when connected. It happens more than you would think it should.
Magic Touch
Austin Texas
Byron
Years of Experience
15
Role
Business Owner
Thanks Dwain! I will check this evening!
