PermaScent
icleancarpetz
Cleaning Professional
Rafael Samson
Rummaging through my shelves last night found a couple of gallons of PermaScent berry fragrance. Nice fruity fragrance. Bought it years ago on the hype of bulletin board must buy.
Is this stuff still on the market and is it any good? No dilution rate on the label other then use as is.
Can’t seem to find it on the net either. Did they go out of business? Duane?
Can’t type his full name here either....bad blood between the him and the High Priest?
I liked Duane but orders would take too long to arrive and one time was misplaced. At the time I like his HARVARD plain labeled products.
And I think your deo is solvent based so it should still be good.
Just shake it it up.
Reactions: icleancarpetz
I don't recall that one but if it's sat for years I'd be a little concerned.
If you use it, do it on rentals or somewhere you aren't depending on it. As Jimmy said shake it well, it's surely separated by now to some degree.
Duane is out of biz afaik ....at least chems and truckmounts
here is the info from his old site....although it probable says this on the bottle
PermaScent is our "oil- based", non- water- soluble odor counteractant. As "Perma" in the name implies, it's very long- lasting. It's also highly concentrated so that a little goes a very long way.
Wild Berries is the original fragrance that was and is so popular and madePermaScent the favorite of many of our customers.
DIRECTIONS:
Use sparingly! Spray around the borders of rooms to be deodorized. May also be misted onto central air system filters to really penetrate all areas of a dwelling. BE SURE TO REMOVE AIR FILTERS FROM CENTRAL AIR UNITS WHILE SPRAYING. DO NOT SPRAY INTO AIR SYSTEM WHILE THE UNIT IS RUNNING!
I'd just use it to slather on my balls on a hot day.
Reactions: Jimmy L
Hack Attack
Dan
Duane ... opportunity wasted
I've got 1 of his rumbling in my van.. NZ's admittedly not global domination but I know there are a few of his here, don't know of any other independant makers that are here
