Oxidizers and Reducers
Shawn Forsythe
A short clinic on the differentiation and use in spotting.
Presented at Mikefest 2008
Preface
Stain Guides are the preferred means for directed activity when using any reducers or oxidizers. This is because individual chemistry of reactants and accelerants vary between manufacturers of prepared products. These guides take into account these variances and give individual instruction to process so as to avoid unpredictable results.
As a general rule, spots should always be cleaned using an emulsification or solvent extraction to remove all removable components aside from actual chemical action. Heat and acidity should be avoided to ensure that spots which are not set, do not evolve into stains which are more difficult to address.
What creates color in a chemical (stain or spot)?
Chemicals that exhibit a color do so because a part of the molecules interact with light to absorb certain wavelengths, or to reflect them. They can also alter wavelengths, so that a color, which is not present in the incident light, is reflected back as changed to another color. If a chemical substance exhibits a color, the portion of the molecule that exhibits the color is called a “chromophore”:
Certain molecules have an affinity to fibers, either due to physical properties, such as stickiness, particle shape, or by an electro-chemical bond. Emulsifier and solvent textile cleaning is used to break physical bonds, and suspend soil(spot) elements in water or some other solvent, so that it can be extracted by vacuum or abs
orption(towel).
These cleaning process are sometimes ineffective if the spot contains a staining element. A staining element is a portion of the spot, which cannot be removed by emulsification or solvent cleaning.
One means to “clear” a staining element is by bleaching. A bleach alters the stain element’s chromophore in such a manner as it becomes colorless.
Types of Bleaches
There are several types of bleach, but most fall into two classes. That being oxidizes and reducers. Oxidizers either add oxygen or gain electrons from a reactant, while reducers remove oxygen or lose electrons to the reactant.
Chlorine bleach usually contains sodium hypochlorite. However, due to problems with fiber degradation, unpredictable results, and residual activity, sodium hypochlorite is almost never used in carpet or upholstery spotting.
Oxygen bleach contains hydrogen peroxide or a peroxide-releasing compound such as sodium perborate or sodium percarbonate. Other bleaching agents include sodium persulfate, sodium perphosphate, sodium persilicate, their ammonium, potassium and lithium analogs, calcium peroxide, zinc peroxide, sodium peroxide, carbamide peroxide, chlorine dioxide, bromate, and organic peroxides (e.g., benzoyl peroxide).
Most oxygen bleaches work best in hot water. Additives such as tetra acetyl ethylene diamine allow the hydrogen peroxide to work in warm water (50° C).
While most bleaches are oxidizing agents, other processes can be used to remove color. For example, sodium dithionite is a powerful reducing agent that can be used as a bleach.
How a bleach works
Oxidizing bleaches like hydrogen peroxide break the molecules at the double bond of a chromophore. This results in either a shorter molecule that does not absorb visible light, or a molecule whose chromophore is either shorter or non-existent. A shorter chromophore will absorb light of a shorter wavelength than visible light (such as ultraviolet light), and so does not appear colored.
Reducing bleaches such as sodium bisulfite or sulfur dioxide, convert the double bonds in the chromophore into single bonds, eliminating its ability to absorb visible light. Sometimes the reaction is reversible, where oxygen in the air reacts with the molecule to repair the chromophore, and the stain returns.
In addition to chemicals, energy can disrupt chemical bonds to bleach out color. For example, the high-energy photons in sunlight (e.g., ultraviolet rays) can disrupt the bonds in chromophores to decolorize them.
Several molecular structures and physical phenomena give rise to color or darkening on a fiber. Molecular structures containing conjugated centers of unsaturation (double bonds) such as phenols and carbonyls all cause vibration of bonds by light wavelengths, shifting absorption of light from the invisible or colorless ultraviolet range to the visible light range. By breaking up the conjugated system, colored compounds become colorless, i.e. stains become invisible. This can be accomplished by breaking or saturating the double bonds. The carbonyl groups can be reduced to alcohols, or oxidized to carboxylic acids, both colorless compounds.
When to Bleach
Bleaching is done when physical removal and emulsification cleaning has ceased to be effective at rendering a satisfactory removal of the spot. It is said that a spot becomes a stain when chemical alteration of the spot element is required to render the spot non-conspicuous. This does not always mean removal. Bleaching often means simple alteration of the spot element to no longer visible. The spot may still be there, but is no longer able to be seen.
The type of stain will help to determine if bleaching will be effective. Fresh stains of an organic nature with very little penetration into the fibers or pigmentation are usually successfully removed by cleaning methods without the use of bleaching. As a rule of thumb, stains, which have been in a fabric for more than three months, are usually considered 'set'. This means that usually they have successfully bonded, or reacted with the fibers to an extent that the substance is not removable or alterable.
How to Bleach
Both oxidizing bleaches and reducer bleaches are either sold as two part components, or 1-part solutions utilize the actual staining element as part of the activation media.
Oxidizing compounds are generally unstable. So packaging of product is done to minimize the off gassing of oxygen during storage. This is often accomplished through maintaining purity of relatively stable compositions, and then adding destabilizers to then cause the oxidizer to liberate the elemental oxygen, that is then free to react with the staining element.
Using a small amount of an alkaline (such as ammonia) to an oxidizer causes the release of greater amounts of oxygen. An alkaline will accelerate oxidizing bleaches.
Using a small amount of an acid (such as acetic acid) to a reducing agent hastens the reduction reaction. Acids accelerate reducing agents.
One should be aware that natural fibers like wool & cotton are susceptible to damage from chemical reactions. Sodium Percarbonate, often used for its oxidizer properties, is a fairly strong alkaline (sodium Carbonate. Alkalinity on natural fibers tends to degrade them. In these cases, using an oxidizer without a high degree of alkalinity is preferred, such as Hydrogen Peroxide. The peroxide can be accelerated with either heat or UV. U.V. is by all means to the preferred method IF the stain material is unknown.
Acceleration of bleaching action
Oxidizers:
Heat
Alkaline
Ultraviolet Light
Reducers:
Heat
Acid
Basic chart of known stains and first choice to remove
Reducers
Betadine/Iodine (Oxidizers will often work also)
Candy (Red Food dye) **
Kool Aid (red)
Cough Syrup – red
Hair Dye
Hi-lighter –Yellow or Green
Oxidizers
Wine
Blood
Coffee**
Tea**
Cough Syrup-Yellow
Curry (needs accelerant)
Feces**
Highlighter red or blue
Ink**
Mold & Mildew stains
Dispersed Dyes (Mustard, Curry, Turmeric)
Real Fruit Juice
Permanent Marker**
Plant Stains**
Toilet Bowl blue
Urine
Vomit**
** Require supplemental action in addition to oxidation/reduction decoloring(i.e. emulsisification and/or solvent removal).
Most any staining element requires preconditioning and extraction using water as a rinse agent.
Reducing agents are vastly improved with heat. Therefore, use of a steam iron, or a steamer is often indicated.
Unknown Stains and order of trial
Because heat and acidity are both part and parcel to reducing procedures, they are used LAST in any situation where you may choose to use one or both methods of bleaching. Therefore, always use the oxidizer first, and then gauge the reaction. Extract, and then use the reducing agent. OXIDIZER FIRST, THEN REDUCER
There are exceptions to this rule. Consult stain guides for individual product lines.
Additional notes:
Oxygen bleaches often work by liberating oxygen in a manner by which an effervescing does occur. effervescing is the emission of small bubbles. The physical manifestation and collapse of these bubbles create a monumental physical action at a very microscopic level. This physical action creates a great deal of movement, or agitation to soils of the 1-4 micron range. This aids greatly in removal, and is the basis for soil removal of popular processes, such as CD. This same action can be of help, in addition to oxidation, for removal of soiling such as filtration.
As discussed, alkali accelerates hydrogen peroxide’s liberation of oxygen. But almost any contaminant will cause a reaction, and not always a good one. Certain acids can have some unpredictable results if combined with hydrogen peroxide. So it is best not to experiment with any acids “on hand” in any manner, to achieve a desired effect. For example, if one uses acetic acid in an effort to accelerate hydrogen peroxide, some of the reaction will create another compound called peroxyacetic acid. Peracetic (peroxyacetic) acid is a highly corrosive organic peroxide that will bleach out most any dye, and degrade natural fibers. Many people who have used this combination literally bleach out all color.
Hydrogen peroxide and ammonium hydroxide. Ammonium hydroxide is amongst the fastest & controlled means to liberate the oxygen from H2O2.
The preceding document has been refined from the handout at Mikefest. In fact, there were typographical errors that were changed for accuracy. Thanks to those at Mikefest who caught the errors.
Shawn Forsythe
Sorry Marty,
That is the short version.
You'll have to go to the supermarket for the "Rug Doctor " amateur adaptation.
GRHeacock
Thanks, Shawn!!
Some good info there, even for the chemically challenged.
A nice presentation, I thought.
Gary
Shawn;
Thanks for posting your explanation.
I've been doing quite a bit of Ultraviolet acceleration of oxidizers lately.
I've found that the "combo" will take out stains that oxidizers alone can't remove without color loss.
There are many situations where I go with reducers first (w/o accelerants) just because I want to "eliminate possibilities" in a short time frame.
However, if time allows one will waste fewer chemicals going OX first. After a while you develop a feel for exceptions to the rules.
Thanks,
Lee
alazo1
San Jose, Ca.
Albert Lazo
Reducer for yellow and green highlighter
Oxydizer for blue and red highlighter
I'm scratching my head as to why each would work for the colors you list.
BTW, good presentation
Albert
Shawn Forsythe
Lee,
My point is the basic guideline is generally only for UNKNOWN STAINS. You are right, when you have gained experience, you'll begin to classify, thus creating a semblance of "known" from which to add to your own "chart" of experience.
Albert,
I don't even come close to pretending to know the chemical makeup of the particular dyes in highlighters. The information, as is much from the list, is from experience of others who have gone before. Rarely will there be a particular "new to you" redox stain that you can reason through. Thus the chart's purpose, and basic guidelines.
Heck, you'll even find that not all red food dyes will work with a reducer. Most red stains are caused by red dye #40 found in Kool Aid, Fruit Punch, Cough Syrup etc. This dye is easily removed using a reducer. There are other red dyes occasionally encountered such as Red #22 and Red #28 (commonly found in other products, like Pepto Bismol) for example that do not respond to a reducer at all, but can be successfully removed with an oxidizer.
