Help with cleaning vertical mounted blower
N GA
BradFenstermaker
59 Blower installed has alot of crud or rust on the lobes. It is mounted vertical so I am worried about water standing in the bottom if I flush.
Any easy suggestions on how to rinse or clean this baby?
You can still flush as normal...it would seem that horizontal would leave more water in....jus run it for a min or two...the water WILL be gone!
Doesn't vertical mean top and bottom holes...what's the problem?
N GA
BradFenstermaker
BOB what do you suggest I flush with?
No the in/out is horizontal. The blower is mounted standing up.
ONLY clear water.......I start with a small stream and build up so as not to hit it all at once!
The first time ...do it till it comes out clear water!
I would use a little soap to help with the crud,and like Bob said let it run a little and add wd40.
Kevin
