Greenie or Greenhorn guru... Question needs answered TONIGHT
B
B&BGaryC
I need to replace my jets for a cleaning job tonight. I had 4 11002's
My Disty only had 2 11002's and 2 11003's....
How should I put those in? The 3's on the outside or inside?
Or should I just try to salvage my best two jets and run all 11002's?
B
B&BGaryC
Hmm... I just got off the phone with greenie and he told me to put the 03's in the middle....
BTW, green glides customer support rocks.
J
John Watson
are they SS or Brass?
Why are you changing them???
just change the worst of your 2 till you can replace the other 2 Keep them all the same or like Ronny said You will be streaky...
T
I remember when he got his greenhorn....I wouldn't think he needs to change them. But then again I don't know how much cleaning he's done. My next set of jets will be 03's.....
For whatever reason is current 02s are streaking pretty bad, bad enough I don't think there are two good ones to salvage, I wouldn't normally recommend mixed jetting, but after doing some brief testing I noticed the 03s in the middle didn't affect spray pattern as much as you might think on the 12" wand, so I said put em in the middle, get er done, and replace when time permits.
T
Did he try cleaning the jets and filter out? I'm sure he has if he's going to replace.....I guess he's just ran enough water through to wear em out?
B
B&BGaryC
It took me 3 hours to clean a nasty Nylon Berber because I was leaving 2 inch dirt strips through the traffic areas. I finally figured out a creative overlap pattern... But it was seriously like night and day. All through the carpet there were brown and white stripes. At first I thought I had something plugged, took my glide off, fished the hairball out but it didn't make any difference.
that sounds like "fouled" jet, not a worn one.
forgive me for asking the obvious, Gary, but you did trigger the wand and look at the jet spray pattern, right?
a worn jet generally leaves a "cleaner" spot on loop piles/berbers and a pile distortion on some cut piles
KevinD
Kevin Dumas
Straight out cleaning, put the 03's in the middle.
If you run into a job with filtration soiling move the 03's to each end for more flushing power.
Then order 2 new jets of your choice.
B
B&BGaryC
I guess I have only really used brass before, and whenever a brass gets fouled I end up ruining it trying to unplug it....
Plus I wanted to jet up to twelve flow... Micah kinda talked me out of it, so I tried to get the 02's... Went all 03's today. I only cleaned cut pile nylon today, so I can't really know for sure how my dry times were affected because everything was bone dry when I left.
I figured at least 1 jet was no good, if not two... and if I was wrong, I would have some back-ups like somebody had suggested I carry.
I guess somewhere along the line I got confused as to why I wanted to replace all the jets with new ones and when I got handed a mixed set my brain became flatulent.
Any way you slice it, greenglides has the best customer support. I have never actually asked Jeff a question during business hours, and he has never complained, even though they can be stupid questions.
