Getting back into the business. Need advice on machine.
encapman
Rick Gelinas
Yes, it can be run on two 15 amp circuits. As long as the circuits are not overloaded with other stuff at the same time.
  • Love
No, it’s not a good idea for you to go to a Mikey’s fest in the beginning. All that will accomplish is introducing you to equipment you can’t afford and people trying to sell it to you. I’d suggest you talk to @Jim Pemberton
He’ll give it to you straight without confusion and not try to sell you something because he sells it. Stay away from Mikey for awhile until you get your sea legs.
Yes it IS a good idea.... unless yor a mouth breather an have the vocabulary of an orangutan...you jus might get some great ideas AND possibly meet a few people that jus may turn out to be great friends thru out yor life....and hey we all need friends! Don we?..
And get a direct drive truck mount and be some body!
  • Love
Reactions: Nate The Great
Too bad you won’t be able to see Bawb use a glided wand as a tripod to hold his ol’ coot azz up.. :lol:
I second a Direct Drive unit..
I met a couple of Bob’s during my first year in this business at my first IICRC class. They were promoting the sale of aquaguard.
Have you run a PEX? I get all the drying time I need on commercial carpet. It puts out excellent heat for crusted baby spit up, or anything else where heat is required. I would hate having to use a porty of any kind in residential, but it’s the cats ass for commercial.
It's a good machine for what it is, just not what I prefer.
And unlik Pigman, make sure yor toofs are in and have minty fresh breath.....!
Reactions: hogjowl
Not sure if Chris Lee still has his Genie .....but its still JUS LIK NEW and i would give a TWENTY YEAR WARRANTY on it. Its the stainless one that i last built! Last i heard he was axing 15 K truck an all.....!
TURN KEY !!!!!
Reactions: SamIam and hogjowl
You can use a portable and use a booster for longer hose runs, also a heater will help, propane or diesel.
A used truck mount would be a world of difference.
I used portys years ago, and would never use one now.
To much work.
Reactions: Kenny Hayes
TURN KEY !!!!!
Twenty year warranty.....and not one funny comment......im playin to the wrong room here!
icleancarpetz
Rafael Samson
Keep the lawn care business. Do both. Be about your grind if you can handle both. One will supplement the other when slow times boomerang around for either.
Keep a portable for portable jobs.
Get a decent running van and install an ez maintenance tm without the bells and whistles that you can work on yourself when it needs attention.
All thats needed for TM:
Kohler Command 27
Pump
#4 blower
Silencer
Custom Heat Divertor ss box
Heat Exchange or Diesal heat set up
Check out Johns Hot Heat Exchange for simplicity tm
Check out Pembertons as well.
Best wishes
Rob Grady
Rob Grady
Sounds funny coming from you with your pidgin english
Lol
Reactions: bob vawter
FyreLyter
Steven Dillon
I did have a trailer set up with a portable, generator, hose reels and little giant heater and vacuum boosters. Something I built little by little, slowly pulling my porty outside the house. I do not at all recommend this! The setup and spiderweb of cords and hoses and upkeep on each individual piece could get maddening. I eventually bought a truckmount and still kept the porty for those jobs I needed it on. I have since sold my truckmount and only have my porty now, since I am now longer cleaning full time.
Use a portable as exactly that. The one I have now can easily pull 50' of 2" vac hose with and clean efficiently, which works great for what I use it for on occasion when I get a side job or clean my own house.
As for Mikeys Fest... GO. You will get hands on experience with other different machines and methods that you can't learn nor want to learn as you go on the your own jobs. Mike really has an awesome thing going that he continually makes better and better.
Anywho.. just my two cents and I hope that it all goes well with you.
Latest Auctions
