- Joined
- Oct 6, 2006
- Messages
- 117,271
the shit you find on the www
HOW TO GET BLACH OUT OF CARPET – METHOD # 1
- As soon as you notice the bleach stain, immediately blot it with water and paper towel. Be careful not to scrub or rub the bleach, as this could worsen the stain.
- Mix ¼ tsp of mild dish soap with 1 cup of warm water.
- Pour the solution over the bleach stain and let sit for about 5 minutes.
- Once the stain has dried, rub it with a cloth or sponge, working from the outside in so you don’t spread the stain.
- Rinse with cold water and dry.
HOW TO GET BLACH OUT OF CARPET – METHOD # 2
- Mix 4 cups of warm water with 2 tbsp of white vinegar.
- Pour this solution over the stained area of your carpet.
- After letting it soak into the stain for about 5 minutes, rub the stain with a cloth or sponge. The bleach stain should gradually start to disappear.
- If the bleach stain is still visible, repeat step 4 until it’s no longer there.
- Rinse the area with cold water. The vinegar smell should eventually disappear.
HOW TO REMOVE BLACH STAINS FROM CARPET – METHOD # 3
- Blot the affected area of the carpet with water and paper towel as soon as you discover the bleach stain.
- Find a crayon that closely matches the color of your carpet.
- Begin to color in the carpet fibers, making sure the color is absorbed.
- Take a wet towel and gently blend the color into the carpet.
after his premises (burnt)
down?
