Any feedback on the new Airpath?
Chads
I'm enjoying it ,it is Quite a better fan than regular style air movers big difference it will dry pretty darn quick with right temperatures I did a about 20' x40' room newer almost shag style carpet and temp was 72 degrees and was raining out side dried the whole carpet completely dry in 55 minutes after done cleaning it one wet pass with one extra dry pass only have a number 3 blower and 2inch hose with a 1'1/2" whip had to move the fan about every fifteen minutes. I like it.
alazo1
San Jose, Ca.
Albert Lazo
So can you answer me this?
When you tilt it, does the air blow straight or out of the sides due to the baffle.?
Another words can you use it in long hallways like the regular fans?.
thanks,
Albert
I only see 2 problems..........
when you put it on high it sounds like the space shuttle taking off
but it does grab some air down and push it across the carpet......
and take papers off desk and walls...............
I just use mine on low and the dry times are some what slower but you should expect that.....
Little bulky but not to bad to cart around....
When you tilt it the air moves more to the side then straight
because of the way the grill (louver) is....
I was really hoping the new MYtee 2700 was going to work.....
they had the removable louver so you could use it for straight up drying.......this fan was a great disappointment.....
T
The Magician
Even tho its plastic a a little smaller than the original. Its still heavy.
