Adding more heat
Lonny
So, I want to keep the porty in the van, on most jobs anyway. I would like to know what kind of heat you would recommend. I have simply been using bucket heaters, which are lethargic to ok, but am looking to spare my pump, etc from the strains of pre heating them. I was thinking of Diesel, or propane, and wanted some opinions, pros and cons. I typically clean at 4-500 psi.
You will get spoiled with the heat, then you'll want more vacuum. Imho. :D
viewtopic.php?f=1&t=36706&st=0&sk=t&sd=a&hilit=oil+fired+propane&start=0
Lonny
Thanks,
This is what I was looking for, I did, in defense use the search button, must be getting cross-eyed.
