A first for water access..
Are those water heaters the same design as the traditional cylinder shaped ones? If so, be careful you don't get a bunch of sediment buildup going in your machine. I've seen a few water heaters drain out some dark colored water from that bottom drain valve
Other than the foliage and views everything about this job is pissing me off..
They're not home they didn't pick up anything as instructed,
150 ft run to the door
White olefin berber that's never seen the same process twice
Latest Auctions
