31hrs Kohler Agies
Shane T
Waukesha, WI
Shane Tiegs
Anyone else running this engine. Been having problems for 2 years with the EFI. Won't compensate for load when the engine temp is over 180 degrees. My Kohler guy is looking into but no help yet.
C
clean image
what computer is it running? older ones run the bosch with return line, newer dont have a return
I have 2, with bosch efi, but they are with lo hours, no problems
you may try hooking clean vac hose 3-4 foot to motor inlet and route to cooler air?
Shane T
Waukesha, WI
Shane Tiegs
I have the Bosch system, about 2100 hours. I have already added several cooling fans. The O2 sensor works fine until the engine is at upper operating temp and unit is put under even the slightest load.
Shane;
Have you looked at the service manual ?
Kohler has it online.
The Bosch EFI has been reliable on our units.
It also has some diagnostics to pinpoint the problem.
Shane T
Waukesha, WI
Shane Tiegs
Larry Cobb said:
Shane;
Larry, What rpm do your unit operate at? Where is the O2 sensor located(how many inches from engine)?
