256:1
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
Would actually depend upon your flow rate and other factors. Should be close to 4 GPH.
Richard's math is exactly correct. It is just his logic that is off.
J Scott W
Shelbyville TN
Clarification
The original question did not state how much concentrated cleaner was added to the 5 gallons. I assumed adding 1 qt of concentrate to 5 gallons of water. Metered at 4:1 this is close to 256:1.
! qt per 5 gallons is the dilution our rinse and emulsifier products use. Several other major manufacturers also use the same dilution.
harryhides
Canada
Tony
You are all wrong and Marty is simply trying to look like he has a clue.
Bill is from Canada where we use real ( Imperial ) gallons vs the weeny US gallon.
One Imperial gallon = 1.2009499 US gallons.
Of course if you are using US product then Scott is correct - just his logic is off.
:mrgreen:
Newman
St. Charles, IL USA
Chris Newman
So the volume of a liquid increases as we travel far too North? :wink:
I wonder how much volume a gallon equals in Alabama?
Ron Werner said:
gallons get smaller the closer you get to the equator
They are back to a real gallon again by the time you get to Australia
Must be the same reason your guys health care is alot better? :twisted:
Just razzing the guys up top.... :lol:
